Does the Bosch Injection pump on a 46 IHC TD9 have motor oil in it or does it use diesel internally as lube? If it uses diesel internally as lube is that why you are saying the overflow will find its way into the motor oil?
If that is the case ... I hadn't thought of that but that sounds like what is happening to my TD9... I have not smelled the dip stick, not milky, but I did start leaking around the rear main seal.
Just got a Adams 46, TD9 motor grader and just got it running again, Oil psi. 50+, old gauge, it also has a "bad case of the all overs". Needs a little work all over.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
