Re: Farmall Super A hydraulic leak
Posted by ken house on October 16, 2014 at 14:28:57 from (173.242.240.3):
In Reply to: Re: Farmall Super A hydraulic leak posted by henhawk1969 on October 16, 2014 at 08:44:56:
the THREE bolts, at the rear, need to come off first. leave one in the hole loose, until the front is loosened and two bolts removed; remove the last of the bolts at the rear and you may have to bump , with a hammer to get it (the pipe) to release (bump on the flange only, not the pipe itself). the front will have to come loose, because you will not be able to clean the gasket, on the rear, without removing all the pipe. good luck
do not prize on the pipe with a bar. do not
  Upload Photo  Select Gallery Photo  Attach Serial No List
