Re: Utility 300 chokes down
Posted by D Slater on October 16, 2014 at 18:15:20 from (184.14.184.128):
In Reply to: Utility 300 chokes down posted by webbdw on October 16, 2014 at 18:00:46:
To eliminate or confirm a fuel flow problem. With plenty of fuel in the tank remove the carburetor bowl drain plug on level ground and check the flow. Make the left side higher and check the flow. If flow is different than level check the float operation. bent or leaking on one side, rubbing the bowl someplace or a problem at the hinge. Shut fuel off before removing drain plug then turn valve back on when testing.
  Upload Photo  Select Gallery Photo  Attach Serial No List
