Posted by gene bender on October 17, 2014 at 02:10:46 from (67.55.226.121):
In Reply to: Farmall b engine posted by ken4831 on October 16, 2014 at 18:27:56:
You need to remove the pan so you can see the bottom of the sleeves it mite take a day or so for coolant to show.The head gasket can also let coolant into the oil thats why removing pan you can determine if one of the rubber rings at the bottom of the sleeve is the culprit or head gasket. Usually if its the head gasket problem will be at the rear. If its the rubber ring in the sleeve it can take some time to show that you can see and it will usually be only one that leaks.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
