Re: Block heaters
Posted by jimb2 on October 17, 2014 at 17:17:14 from (99.241.118.87):
In Reply to: Block heaters posted by Glenn D on October 16, 2014 at 14:27:03:
Hi Glenn, we live in eastern Ontario and when
Dad had B-414D, 434 and 384, all BD-154 UK
Diesels, we used a 1000 Watt lower rad hose
heater in the B-414D and the 434. When he
traded 434 for 384, he made dealer install a
re-circulating tank heater.
I thank tank heater was 800 Watt. In all cases
on the coldest days, plug tractor in for an
hour and it was good to start.
JimB
  Upload Photo  Select Gallery Photo  Attach Serial No List
