Re: IH DT436 oil from breather help again .-posted in combines t
Posted by 151 on October 18, 2014 at 08:44:04 from (104.36.234.114):
In Reply to: IH DT436 oil from breather help again .-posted in combines t posted by Dave from central MN on October 17, 2014 at 18:01:40:
have a 206 D motor in case IH 595 tractor do that in was 2 things one was the baffle in valve cover weld broke it was floating around in cover the main thing was # 4 piston top ring broke may not be your case if all else fails do a compression check maybe mine run some what good that way just stated to blow oil out dip stick
  Upload Photo  Select Gallery Photo  Attach Serial No List
