Re: IH DT436 oil from breather help again .-posted in combines t
Posted by pete 23 on October 18, 2014 at 10:31:20 from (74.33.79.62):
In Reply to: Re: IH DT436 oil from breather help again .-posted in combines t posted by Ted in NE on October 18, 2014 at 06:45:08:
The change of tappets were to increase camshaft life . The package used a solid tappet with hardened bottom (or disc on bottom from v 8 engines) which is why the shorter push rod. Original tappet is hollow and does carry a lot of oil in it. The wide gap ring allowed more blow by and that is why they went to the top breather. Of course this change also led to more camshaft problems as the oil mist over camshaft was reduced with top breather. The very latest was a larger side breather but I never saw one of them installed on an engine.
  Upload Photo  Select Gallery Photo  Attach Serial No List
