Great to see a young lady interested in old tractors. Don't want to discourage her but since she was going into detail about how the M&W disc brakes could be added to a H. Think she should also mention late H tractors had the SH type brakes along with the SH type crankshaft, clutch, longer axles, sealed beam lights and the same bearings as a SH. Also 4 piston rings were used in the SH. Can think of a few other things but good enough.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
