Re: farmall m shaft in behind belly pump broke
Posted by Paul Shuler on January 04, 2001 at 19:36:00 from (152.163.206.196):
In Reply to: farmall m shaft in behind belly pump broke posted by Bert Mead on January 04, 2001 at 17:19:16:
What RB said makes good since to me. Is it leaking any oil around the back of the motor or dripping from around the back of the oil pan. Could be a leaking rear seal. Mine leaks there and when you look up in the clutch inspection area there is oil on everything.
Post A Followup
: Re: Re: farmall m shaft in behind belly pump broke
