Re: slowing down m
Posted by D Slater on October 19, 2014 at 07:20:42 from (184.14.184.128):
In Reply to: slowing down m posted by tom kurtz on October 19, 2014 at 06:03:45:
Think the 560 ring gear will bolt to a M differential carrier. But no way will a 560 main shaft work in a M without major rework. Short of a low low first attachment or special gears some W-6 have a first gear with one tooth less on the counter shaft driving one tooth more on the top shaft. Will work in a M with the matching reverse idler also installed.
  Upload Photo  Select Gallery Photo  Attach Serial No List
