my 2 cents part 2 - my machine had a big cement block mounted on the rear end. I got the mount and loaded it with old F&H weights, and railroad rails to about 1200 lbs and it was manageable. I have since come into a fork lift frame which I have mounted and with forks, I can load and un-load weight as needed to drive, or just a handy way to move stuff around. I suggest you use the backhoe frame to build that; or see if you can find a bobcat fork rig that can be adapted to your back how mount. I have a 350U with front loader and full on back hoe. It drives nicely as there is a lot of rear end weight. I hope that helps. d
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
