Re: 1940 H High Oil Pressure
Posted by Janicholson on October 19, 2014 at 15:17:33 from (74.60.94.18):
In Reply to: 1940 H High Oil Pressure posted by cleddy on October 19, 2014 at 10:13:27:
The typical Farmall runs very high oil pressure, typically 75 PSI or more. The prior posts are correct. The Square section "Oring" is in the groove. it is a deep groove. The old ring will be nearly as hard as steel. Using a sacrificial old screw driver sharpened to make a tiny sharp chisel will help. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
