If its a distributor ignition as you claim (NOT a Magneto) what you call a "kill switch" I would call an Ignition Off/On Switch but that's not the issue. I assume it hasn't been converted to an Alternator in my answer.
A Magneto kill switch circuit simply attaches to the mag and if the circuit becomes grounded theres no spark.
A distributor ignition Off/On switch simply feeds hot battery voltage down to the Coil if ON but no voltage if turned OFF.
If you turn an Ignition switch off yet the tractor keeps running and you kill it by choking or some other method, the coil will continue to draw around 4 amps which will eventually drain the battery plus the coil will get hot and the points can be damaged YOU NEED TO FIX THAT IGNITION SWITCH PROBLEM
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
