Most likely it is a sticking relay in the regulator. One side of the light comes from the key switch. The other side is attached to the GEN or ARM terminal of the regulator. When the key is first turned on the light grounds through the brushes and armature of the generator. When the generator starts to charge the voltage rises on that wire until the cutout relay in the regulator closes. When the relay closes the voltage is the same on both sides of the bulb and the light goes out. If the relay sticks closed the BAT terminal is still connected internally in the regulator to provide power in the GEN terminal. When the switch off you still have power coming from the regulator going through the bulb and grounding through the ignition system and fuel gauge which causes the light to glow.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
