Re: Wheatland tractors
Posted by wisbaker on October 20, 2014 at 15:38:05 from (173.26.84.185):
In Reply to: Wheatland tractors posted by Luke470 on October 20, 2014 at 14:17:27:
You'll hear "Wheatland" or "Standard" tractor terms used interchangeably. A wheat land
or standard tractor usually has a lower profile with smaller tires and a wide front
often the tire track isn't adjustable. Back about 100 years ago when they started
making tractors they were all pretty much standard. International Harvester got this
bright idea to make a narrow front tractor with higher ground clearance to allow
farmers to cultivate row crops. International then started calling the row crop tractor
McCormick Farmalls, the standard tractor were Deerings, then later Internationals.
Often the manufacturers made their biggest tractor a standard only version Like the
International 40 and 9 series tractors, The John Deere D, R, 80, 820 and 830 and the
Case L and LA. When you grow wheat and other small grains you can't cultivate it so you
don't have the need for the maneuverability and high clearance found in row crop
tractors. Also wheat farms were bigger or tended to be single crop farms earlier so
they made bigger tractors to cover more ground. Wheat land farmers basically used
tractors for tillage, planting and harvest.
  Upload Photo  Select Gallery Photo  Attach Serial No List
