Re: Farmall C hydraulic pump
Posted by Dennis K (WA) on October 20, 2014 at 18:30:04 from (24.21.78.195):
In Reply to: Farmall C hydraulic pump posted by CharlieNJ on October 20, 2014 at 13:40:20:
Charlie,
I went through the same thing you are about a week ago.
Learned there are at least three maybe four different brands of pumps with different seal configurations.
Mine was a Thompson with an O ring, had a badly worn shaft and the gear was also very loose on the shaft. So, I had an extra and found it to have a lip seal and then learned there are two different sized ID depending on brand and vintage.
Here is what I determined on lip seals,
5/8'' shaft IH p/n 353183R91, SKF6229
3/4'' shaft SKF 7443
SKF and CR are same thing, Napa had it.
SKF has a good internet site for crossing over OEM #S
good luck
Dennis
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
