The hydraulic TA on the 06-56-66-86-3X88 tractors is meant to be used as an extra gear. Treat it like a two-speed powershift.
The exception is any 6XX model through those series. Those have mechanical TAs in them and should be left in direct the majority of the time.
If you use the hydraulic TA as an extra gear it will last twice as long. People who fear the TA and refuse to shift it wear out the high side. Unlike a mechanical TA, you *CAN* wear out the high side on a hydraulic TA.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
