Re: fieldwork using the low side of theTA
Posted by Janicholson on October 21, 2014 at 09:05:56 from (199.17.6.160):
In Reply to: fieldwork using the low side of theTA posted by leeedwin9 on October 21, 2014 at 00:16:31:
I disagree with mu fellow YTers on this issue.
When the mechanical TA is in reduction (handle back) the ramp and rollers are being used, the gears in the planetaries are working (as they are in any automatic trans), and the TA clutch is disengaged (free). This uses up the life of the TA throwout bearing, but not much else, and they seem to work for 50 years (not too many TA throwout bearing failures show up on here). The Ramp and rollers are not harmed by being locked. They are harmed by continuous overrunning as they develop flat spots from dragging over the years.
Over the thousands of hours of mechanical TA use between our family with 3 and neighbors with several, no TA work has been needed, except one neighbor who ""never Used"" the TA until it was absolutely needed to prevent a stall.
His began slipping on TA reduction at about 35 years.
The only caution is free wheeling down hills.
and that is always a thing to remember in reduction.
Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
