Re: 1947 Super A hydraulic pump
Posted by Dennis K (WA) on October 21, 2014 at 09:10:39 from (24.21.78.195):
In Reply to: 1947 Super A hydraulic pump posted by chesshircat on October 17, 2014 at 16:30:16:
I recently went through this on a 'C', same pumps.
3 or 4 different brands, some with O Ring some with seals and two different size shafts for the type with lip seals.
Lip Seal for 5/8'' shaft use SKF6229
Lip Seal for 3/4'' shaft use SKF7443
Both had same OD of 1.25''
SKF # same as CR#
I needed the one for 3/4'' shaft, Napa had it in stock
good luck
Dennis
