Re: IH 300 Utility Brake Issue
Posted by Mark Robke on October 21, 2014 at 09:24:39 from (71.31.20.183):
In Reply to: IH 300 Utility Brake Issue posted by pwyld on October 20, 2014 at 08:50:01:
As I remember,there are 3 (or 2 or 4) balls inside the actuator,and they roll in a groove which narrows as it causes the actuator to expand.They can hang up in the groove,keeping the brakes applied. They can hang up because the ball is worn, or the groove. A different actuator may be needed if the groove is worn.Also the housing brake surfaces may be worn,and you might have to have outer housing machined down a little to compensate the over expansion of the actuator.Mark
  Upload Photo  Select Gallery Photo  Attach Serial No List
