Re: fieldwork using the low side of theTA
Posted by mazemeister on October 21, 2014 at 09:38:45 from (104.148.251.168):
In Reply to: fieldwork using the low side of theTA posted by leeedwin9 on October 21, 2014 at 00:16:31:
your 756 has a hydraulic TA. In high (direct drive), the DD clutch pack is locked. as long as everything is in proper condition, there should be no wear on it.
in TA, the DD clutch is released; again no wear on it.
When in TA, the sprag is transmitting power, and the TA lockup clutch (primarily to prevent over run) is locked. again, no wear there, unless something is wrong and it slips.
When in DD, the sprag is being over run, and although lubricated with trans fluid, it does wear very slowly.
So my advice is, use the TA as another gear, like has been mentioned. when doing stationary PTO work, I like to leave it in TA to prevent excessive wear on the sprag.
if the TA has been replaced with a mechanical diode, there is no sprag, so there is no issue.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
