Re: fieldwork using the low side of theTA
Posted by mkirsch on October 21, 2014 at 10:02:19 from (72.45.143.81):
In Reply to: fieldwork using the low side of theTA posted by leeedwin9 on October 21, 2014 at 00:16:31:
Rusty and Jim, you are both thinking "old school" with the MECHANICAL TA found on Super MTA, 300, 400, 350, 450, 340, 460, 560, 660, 504, 606, 544, 656, 666, and 686 tractors, for example.
Any other tractor with a TA has a HYDRAULIC TA, which is completely different from a mechanical TA. There are too many to list, but all other 06, 56, 66, 86, 3X88 and 6X88 series tractors have this type of TA.
Believe what you will, but the fact of the matter is, the hydraulic TA is most certainly meant to be used as an extra gear. mazemeister's explanation of the way the mechanism works is an excellent one, and indicates that it is actually LESS wear in TA speed with a hydraulic TA.
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
