Re: fieldwork using the low side of theTA
Posted by pete 23 on October 21, 2014 at 10:18:47 from (74.33.79.62):
In Reply to: fieldwork using the low side of theTA posted by leeedwin9 on October 21, 2014 at 00:16:31:
You know the old saying, six of one, half a dozen the other. The sprag in hydraulic ta's or rollers in mechanical ta's wear some while in direct drive as they are being rolled over all the time. Both the sprag and rollers wear in TA as they are carrying the torque of the load at that point. That is how the grooves get imprinted in the ramps on roller type from rollers being forced into ramp, and how the edges of the sprags eventually give up the ghost . Some just wear out, other break up, turn over etc. Seen it both ways over the years.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
