Re: fieldwork using the low side of theTA
Posted by cjd12000 on October 21, 2014 at 16:53:59 from (166.137.252.54):
In Reply to: fieldwork using the low side of theTA posted by leeedwin9 on October 21, 2014 at 00:16:31:
If you ever get to install a ta it will come with a note that it should be used evenly between both sides to prevent premature failure and even wear.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
