Re: Lp Farmalls
Posted by Nebraska Cowman on October 22, 2014 at 04:52:05 from (166.182.3.16):
In Reply to: Lp Farmalls posted by dej(Jed) on October 21, 2014 at 04:51:26:
Value is where you find it. LP engines burn
clean and will likely be in better conditions
than their gas counterpart. Albeit southern
tractors have a reputation of being run by
hired help. Not always the most careful
operator. Also LP engines are significantly
higher compression and components are in demand
to tractor pullers. Restored LP tractors make
nice show pieces. They add interest in areas
where they are not common. The system is simple
enough once you get over being afraid of it
unlike gasoline, the fuel in the tank never
goes bad. Modern replacement Impco converters
are readily available. The Ensign are no longer
supported.
  Upload Photo  Select Gallery Photo  Attach Serial No List
