Re: 2400A or 454 PTO Issue
Posted by jimb2 on October 22, 2014 at 13:43:52 from (99.241.118.87):
In Reply to: Re: 2400A or 454 PTO Issue posted by JeffatSE on October 22, 2014 at 11:09:58:
Jeff, if you have a shop manual, it describes a hydraulic pressure test for the PTO clutch pack.
One more test for worn splines on pressure plate, engage the PTO and if the tractor has remote hydraulic outlets, dead head the remote outlet and listen for relief valve buzzing, engine being lugged down and watch to see if PTO stops. If the relief valve stops buzzing and the PTO stops, the splines on the pressure plate that drive the PTO shaft could be worn out but still have enough grip to drive the hydraulic pump but not a PTO driven implement.
JimB
  Upload Photo  Select Gallery Photo  Attach Serial No List
