Re: 300 Generator
Posted by 39H on January 05, 2001 at 07:10:12 from (216.29.40.162):
In Reply to: 300 Generator posted by Lee K. on January 04, 2001 at 21:25:11:
Had the same thing happen to me. On mine it turned out that for whatever reason the generator just couldn't quite pull in the cut-out relay when I started it up. Apparently when I would repolarized it, that gave it just enough more umph to pull it in. I reduced the spring pressure that holds the cut-out points open and mine has worked perfectly since. Next time you start the 300, instead of polarizing the generator try pushing the cut-out closed. If it stays closed and charges OK, you might try my "fix"
Post A Followup
: Re: Re: 300 Generator
