Posted by John T on October 24, 2014 at 09:09:38 from (216.249.72.121):
In Reply to: Cub LoBoy Coil posted by bob landers on October 24, 2014 at 08:43:20:
If you work through my Ignition troubleshooting procedure it can help find the problem. As the points are usually closed if all is well and wired right there's usually no voltage (with respect to ground) on the coils output (to distributor) terminal, see my procedure.
"First question: shouldn't the coil have some resistance, maybe a few ohms?"
YES the coils LV primary between the little + and - terminals should be continuous and have a resistance of around 1.2 to 2 ohms for a 6 volt or 2.5 to 4 ohms for a 12 volt coil.
"Second question: If it's bad and I think it is, would it better to get the hotter coil that requires external resistance?"
While a 6 volt coil would require a series voltage dropping (12 down to 6) ballast resistor if used on a 12 volt tractor, I wouldn't think of that as a HOTTER coil as you asked.
On a 12 volt tractor you can EITHER use a full true 12 volt coil (NO Ballast required) or a 6 volt coil PLUS the ballast. A 12 volt is easier and needs less wiring and no ballast etc. to fool with.
One reason however to use a 6 on a 12 volt tractor is if you have a ballast by pass circuit/system is it can improve starting (hotter spark) in cold weather
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
