Re: farmall m shaft in behind belly pump broke
Posted by Charlie on January 05, 2001 at 07:55:13 from (209.130.220.58):
In Reply to: farmall m shaft in behind belly pump broke posted by Bert Mead on January 04, 2001 at 17:19:16:
With the belly pump removed its relatively easy to get the clutch out and take a look at it. Sounds like a good chance its covered with oil - maybe the rear seal is leaking. There is nothing someone could do to the drive shaft when removing the pump that would allow the tractor to move at all.
Post A Followup
: Re: Re: farmall m shaft in behind belly pump broke
