Re: farmall 340 stuck in gear
Posted by pete 23 on October 25, 2014 at 09:39:14 from (74.33.79.62):
In Reply to: farmall 340 stuck in gear posted by Ramp;W on October 25, 2014 at 06:50:07:
Did it go together easily. It is problematic to get the main shaft pilot bearing to enter the TA output shaft and you may have damaged it. That could cause your problem. I always put tractor in 4th gear to hold shaft up , rubber band the pilot bearing and turn input shaft through TA while getting pilot bearing started into shaft. Plus, want no help pushing it together as that only causes problems. On tractors with belt pulley cover it is easy to see what is going on but with the blind hole on that one and like a 656 it is more difficult. Hopefully this isn't your problem but it is suspect. I would take cover off TA and check for freedom of movement of planet gears wit TA lever back and clutch held down.
  Upload Photo  Select Gallery Photo  Attach Serial No List
