Re: Oil for char-lyn poower-steering
Posted by rustyfarmall on October 26, 2014 at 09:11:47 from (208.126.186.41):
In Reply to: Oil for char-lyn poower-steering posted by mark in mo 2 on October 25, 2014 at 11:32:21:
If it is a stand alone unit, probably ATF. If it uses any part of the tractors existing hydraulic system, then you should use the recommended fluids.
For what it's worth, the newly installed Char-Lynn unit on my M seems to be very happy with the "303" universal hydraulic fluid that is in the belt driven, add on, live hydraulic system that runs the everything else.
I've also learned that my ancient cherry picker (engine hoist) is much happier with the 303 fluid instead of ATF.
