Posted by old weldor on October 26, 2014 at 18:59:03 from (72.171.192.119):
In Reply to: 300 burns up points posted by VaGasman on October 26, 2014 at 18:32:11:
I have a farmall H that acted the same when I first got it. After it was running and then sat a few days, I would have to re gap the points to get it running again. It had a couple problems, it was converted to 12 volts and the resistor was hooked up wrong.when it finally refused to run at all, I discovered that the distributor wasn't turning. The pin holding the gear in place on the shaft had sheared because the hole in the shaft and gear was wallowed out. It has a verticle mount dist. because a live hydraulic pump had been installed.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
