Re: 300 burns up points
Posted by Bob on October 26, 2014 at 19:06:13 from (64.255.159.192):
In Reply to: 300 burns up points posted by VaGasman on October 26, 2014 at 18:32:11:
"Universal coil" doesn't tell us much.
ASSUMING it is a coil for use on a 12 Volt system WITHOUT needing a primary circuit ballast resistor, HOPEFULLY, the coil is not the issue.
If that is the case, poor quality breaker points likely are issue.
Plus, once you have filed points, they are JUNK, only good enough to get the tractor back to the yard, for convenient point replacement.
I will get flamed for that comment, but it is true, most of the time.
If you want to argue, look at the smooth, shiny face of quality new points, then take a look at a set that has been filed/hacked/tore up/ruined.
  Upload Photo  Select Gallery Photo  Attach Serial No List
