Re: 300 burns up points
Posted by pete 23 on October 26, 2014 at 19:31:18 from (74.33.79.62):
In Reply to: 300 burns up points posted by VaGasman on October 26, 2014 at 18:32:11:
You have to determine if your coil requires a external resistor or not. Simple ohm meter test of primary winding will tell you that. Less than two ohms, you need resistor. Approx 4 ohms, it is a straight 12volt coil and does not need resistor. Most coils used on 12 volt systems DO require a external resistor. Many other ways to check this also but this is about as simple as I can state it.
  Upload Photo  Select Gallery Photo  Attach Serial No List
