Re: 706 not getting fuel to 2 cylinders
Posted by pete 23 on October 26, 2014 at 19:44:41 from (74.33.79.62):
In Reply to: 706 not getting fuel to 2 cylinders posted by Cory Schmidt on October 25, 2014 at 16:48:45:
The rings to guide gasket are only used in the end cylinders and not middle two. On the gaskets, early models used same old gasket the trucks and 560 used. When we started having all kinds of problems with intakes leaking, IH came with a ribbed metal gasket that had asbestos embossed material on the intakes. They also came with the plated grade 8 bolts and hardened steel washers. Those good washers are no longer available. The ones they subbed to now are not a good fit. The new combination did a real good job but you had to split the manifold before installing as intake part of gasket is thicker. Many will fit gasket packages use the old style gasket and when you start mixing and matching gaskets and manifold you have to know what is going on. If you machine the manifold all in one piece and don't split it you have to use the gasket that is same thickness all the way, intake and exhaust. I hate those gaskets as they ruined more than a few engines in their hay day.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
