Posted by Dean Olson on October 26, 2014 at 20:45:46 from (107.129.21.194):
In Reply to: super c rear axle posted by bass on October 26, 2014 at 12:21:09:
Outer is easy.
Remove tire and wheel, remove bolt cap covers and seal,gasket, and felt are easily accessible.
Inner is a project and a half. Top cover must come off, although rumor has it it can be done through the PTO hole after removing PTO. Axle retainer bolts come off, axle housing can now be removed from trans case, bull gear will drop into bottom of case. More than likely the axle will be grooved where inner seal used to seal. It's been leaking long enough for outer seal to fail. That will need to be welded up and turned or speedy sleeve installed. Outer seal surface is probably grooved also. Maybe it's 2 projects to get it done "right".
I personally just replaced the outer seals, felts, and gaskets then pumped them full of fresh grease. So far they havent leaked.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
