Posted by John T on October 27, 2014 at 06:09:21 from (216.249.72.121):
In Reply to: 300 burns up points posted by VaGasman on October 26, 2014 at 18:32:11:
There can be a few (and more) reasons for premature point failure.
1) Excess coil current, it should be in the range of 4 and less amps.
2) Weak or completely open Condensor or one that's not the right size (MFD Rating).
3) Coil with too low LV Primary Resistance (thus allowing more then 4 amps of current the points have to switch)
See if that coil has a LV primary winding resistance (between little + and - terminals) of around 2.5 to 4 ohms????????? If so it should be fine on 12 volts no ballast required. If its way less, like 1.2 to 2 ohms IT NEEDS AN EXTERNAL SERIES VOLTAGE DROPPING (12 TO 6) BALLAST RESISTOR otherwise the points will burn up quickly.
A 12 volt coil may be labeled "12 Volts" or "12 Volts NOT for use with Ballast" HOWEVER if tis labeled "12 Volts requires Ballast resistor" its a 6 volt coil and needs the ballast or it will run hot and the points burn up quickly.
I suspect the coil may be a 6 volt unit or needs a ballast resistor therefore its causing excess current burning up the points or else the condenser is bad or open or not wired correct or the points are just junk quality
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
