Re: Super A PTO 90 degree spacer Question
Posted by RTR on October 27, 2014 at 08:26:34 from (68.186.180.18):
In Reply to: Super A PTO 90 degree spacer Question posted by mkirsch on October 27, 2014 at 05:26:23:
Thank you, I actually found the bushing(s). One about 1 inch or so long and the other is a thick washer style.
