Re: MD repower
Posted by Centex Farmall on October 27, 2014 at 10:29:55 from (72.105.165.14):
In Reply to: MD repower posted by DeltaRed on October 27, 2014 at 07:10:18:
If you can find a GMC V-6, that would be worth looking into. It's shorter and had a deep block and was made to work hard. Possible downside is that it will want some RPM to get in it's powerband.
Someone posted pics of one at a show with a GMC V-12, and it fit well inside the frame.
Cut and paste this for starters:
https://www.flickr.com/photos/22759495@N08/9695439738/
I've also seen first hand a 6.2 diesel in one and it fit very well. Only a slight mod to the frame for oil filter.
  Upload Photo  Select Gallery Photo  Attach Serial No List
