No need to remove the cover. The hardest part is handling the wheel and axle housing. It can be done by having the wheel on a greased board. Replace two of the bolts with longer ones to act as guide pins. Support the center of the tractor. remove the rest of the bolts. slide the wheel out on the board as far as it will go. It will only be about an inch or so. You can use a gasket or if you clean up both surfaces so they are oil free you can used a bead of RTV silicone sealer and forget the gasket.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
