Re: MD repower
Posted by Bob on October 27, 2014 at 17:10:49 from (75.239.3.190):
In Reply to: MD repower posted by DeltaRed on October 27, 2014 at 07:10:18:
I vote for a diesel, 'cuz it will already have a governor, vs. a gasser to which you will need to engineer and add a belt-drive governor.
Binder/Ford 7.3?
GM 6.2 (which uses the same bellhousing and motor mount locations as an SBC)?
To those who want to argue, both of them could be set to the same governed speed and HP of the original engine.
  Upload Photo  Select Gallery Photo  Attach Serial No List
