Re: distributor cam Super H worn
Posted by Janicholson on October 27, 2014 at 21:08:11 from (74.60.94.18):
In Reply to: distributor cam Super H worn posted by chuckj1954 on October 27, 2014 at 20:09:46:
It either has the cam bumps worn, or more likely the bushing is toast. Check side to side play on the cam (where the rotor slips on) if you can see it wiggle in the bushing it is bad. .001" is about all the slop it can have. Rebuilt is best or replace the bushing if the shaft is not worn. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
