Posted by NateB on October 28, 2014 at 00:06:50 from (199.120.81.60):
I have a 44 M with a M & W 201PX live pump and a right angle Delco Remy distributor and have an odd problem.
Last winter while pushing snow I could not keep the tractor running- seemed like it was starving for gas so I spent a bunch of time checking the carb to no avail. Finally discovered the distributor was full of oil and fouling the points. I cleaned the distributor up and it ran fine.
I used the tractor in the spring to grade the driveway and had the same problem- much quicker diagnosis this time! Figured the seal on the distributor was failing so instead of using oil to lube the distributor I used grease hoping it would be thick enough not to work past the seal.
Tractor ran fine and used it a few times with no problems until yesterday- same problem!
It was not grease in the distributor so I am guessing it has to be hydraulic oil.
Anyone have any insight? Is this a seal problem or do I have a major leak inside the pump that is pushing pressurized oil past the seals? Are there parts available for the M & W pumps? I searched on-line with no luck.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
