Re: Installing wide front end on Super MTA
Posted by mkirsch on October 28, 2014 at 05:13:09 from (72.45.143.81):
In Reply to: Installing wide front end on Super MTA posted by Smith1000 on October 26, 2014 at 15:59:23:
Nordens are okay. The one I was talking about was the factory IH wide front from the early Hs & Ms. It has the tie rods out front, and is not a very good turner.
I would much rather have a Norden or a Speeco than one of those early factory IH wide fronts.
It also helps to have the wheels and tires on the wide front so it is much closer to "ride height" when you jack it up. Then you don't have to lift the whole thing clean off the ground.
