Re: distributor cam Super H worn
Posted by gene bender on October 28, 2014 at 07:01:10 from (67.55.226.121):
In Reply to: distributor cam Super H worn posted by chuckj1954 on October 27, 2014 at 20:09:46:
Your dist has bad bushings the lobes would not be worn in two places when they are rubbing on a piece of plastic get the dist shaft fixed.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
