Re: Farmall 'A' Plough Required
Posted by El Toro on October 28, 2014 at 07:45:35 from (96.244.7.206):
In Reply to: Farmall 'A' Plough Required posted by seanfitz87 on October 27, 2014 at 07:37:27:
third party image
You can put a Wanted Ad in Classified Ads under Market Place. Make sure all brackets are with the plow if you locate one. Here's the Farmall A
I bought for $100.00 in 1975. It needed a lot of work. New tires, rims, wiring, steering wheel, seat and the engine was stuck. You also need the levers that lift the plow and tilt the point.Hal
  Upload Photo  Select Gallery Photo  Attach Serial No List
