Re: Schwartz wide front end for an M
Posted by rustyfarmall on October 28, 2014 at 14:40:02 from (208.126.186.41):
In Reply to: Schwartz wide front end for an M posted by R Weld on October 28, 2014 at 13:26:34:
The axle tube, axle extensions, spindles, and hubs will probably work on your M. Everything else, including the tie rods, will need to be specific to the M. The cost of those parts will be close to the price of a brand new, ready to go, wide front.
