Re: 686 IHC high low clutch
Posted by 65-and-tired on October 28, 2014 at 21:21:02 from (207.204.209.199):
In Reply to: 686 IHC high low clutch posted by mkirsch on October 27, 2014 at 05:42:09:
[quote="mkirsch"](quoted from post at 11:42:09 10/27/14) Do you mean the torque amplifier (TA)?
Hmm, it shouldn't "slip" in high. If the TA clutch is slipping the tractor should continue to drive in low.
Is that what is happening? If so then your problem is with the TA clutch. Either it's installed wrong or adjusted wrong.
If the tractor is stopping completely you have a problem with the main clutch.[/quote]
Yes the TA clutch.Works fine in low but slips in high. The main clutch is working fine. I will check the adjustment on the TA clutch.
