Re: c-123 motor
Posted by Janicholson on October 29, 2014 at 13:46:32 from (199.17.6.26):
In Reply to: c-123 motor posted by bass on October 29, 2014 at 13:12:52:
Some engine blocks in the series can be increased in displacement to 135cid. Other similar blocks are as much as 153 Cid, but they are not sleeved engines.
There is only one way I know of for positive and that is to remove the head and measure the bore.
Using oil or thick fluid to fill the cylinder when at BDC then moving to TDC and measuring the volume displaced could work if the rings hold the fluid well, then multiply by 4. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
