Re: Heavy duty Clutch?
Posted by Lee K. on January 05, 2001 at 16:00:55 from (205.160.206.85):
In Reply to: Heavy duty Clutch? posted by George on January 05, 2001 at 09:34:19:
If your not using the tractor for pulling it is best to stay with a standard or near standard clutch. A clucth like that is meant for heavy pulling and tillage applications, not utillity and loader tractor work. With a loader tractor, chances are that the clutch is used and feathered alot. When you put on a heavy duty clutch, or a button clutch that you described, the clutch itself won't wear out, but the flywheel and preasure plate assembly wear out a lot faster. This is especially true in loader tractors. A standard clutch will work fine, a button clutch will cause more headaches than it's worth.
Post A Followup
: Re: Re: Heavy duty Clutch?
